COMSOL 4.3 with MATLAB error
I have the code that have for loop.
Before the first loop is finished, we met several error messages
??? Error using ==> mphinterp at 317
mphinterp (292): Java exception occurred:
Exception:
java.lang.RuntimeException: Error in reInitializeModel
(rethrown as com.comsol.util.exceptions.FlException)
Exception:
java.lang.NullPointerException
Exception:
org.eclipse.emf.cdo.common.util.TransportException: java.util.concurrent.TimeoutException
Is it a memory problem?
We have a 16GB RAM.
I increased the java memory to 7GB.
But, I have that problem continually.
Mattia replied below.
here is where you shuold look for your error :-)
But I think that the code 'mphinterp' is not the reason of error.
When I simulate short loops about ~1600, I could get a results
However, if I increase the loops over the 1600, I could not get the results with above error message.
I think that it is not the problem about the code.
May I get the solution?
Kyungnam Kang
0 Replies Last Post 18 févr. 2013, 06:39 UTC−5
Hello Kyungnam Kang
