"Hinge assembly" problem
While going through the solved model 'hinge assembly' given in the COMSOL,
I came across some difficulties. Actually, I have to develop a solid model
involving hinge joint similar to what is provided in the aforementioned
example. However, I could not understand few terminologies used in the
model.
Under solid mechanics (in the model builder of the model) two global
constraints have been defined; under which in the constraint expression
it is written as "mod1.solid.b_rig2-mod1.solid.b_rig3". I did not get
any explanation of each of these terms. Because of these two I am
unable to implement similar hinge connections as well.
The model can be found in Model library> Structural mechanics> Connectors and Mechanisms> Hing Assembly.
Can anyone please help?
1 Reply Last Post 8 févr. 2013, 02:24 UTC−5
Posted: 1 decade ago 8 févr. 2013, 02:24 UTC−5
The 'b' degree of freedom is the rotation around the x axis, as described in "Theory for the Rigid Connector" in the users guide.
The suffix '_rig2' etc. is the tag of the rigid connector to which this DOF belongs.
So the expression "mod1.solid.b_rig2-mod1.solid.b_rig3" forces the rotation around x to be the same for rigid connector 2 and 3.
Henrik
Hi, The 'b' degree of freedom is the rotation around the x axis, as described in "Theory for the Rigid Connector" in the users guide. The suffix '_rig2' etc. is the tag of the rigid connector to which this DOF belongs. So the expression "mod1.solid.b_rig2-mod1.solid.b_rig3" forces the rotation around x to be the same for rigid connector 2 and 3. Regards, Henrik
