Issue importing ipt files from Inventor with the CAD module
Matthieu Dalban-Canassy
I can't seem to import a simple IPT cad file (that has a helix built in) from inventor, the import module gives me an error back saying:
Not a valid ENTITY type for this operation
- Detail: Internal_error_translating_CAD_model
- Detail: File version is not supported
- Filename:...
Is there any version limitation on inventor files or would that be something else?
Thanks in advance,
Matthieu
2 Replies Last Post 2 mai 2013, 16:40 UTC−4
Hello Matthieu Dalban-Canassy
Posted: 1 decade ago 2 mai 2013, 10:34 UTC−4
Hi all,
Got the same problem than you, except this time it is for a .SLDASM file created with SolidWorks...
Could anyone help us ?
Thanks in advance,
Etienne
Hi all, Got the same problem than you, except this time it is for a .SLDASM file created with SolidWorks... Could anyone help us ? Thanks in advance, Etienne
Posted: 1 decade ago 2 mai 2013, 16:40 UTC−4
A torus and worse helix's are tricky geometries many kernels do a poor job generating them.
Have you tried to play with the kernel option (COMSOL or the CAD too one ?
Else is it possible to reconstruct the helix with COMSOL, you can make hybrid CAD, partly imported, partly reconstructed locally (at least that works OK for me in SolidWorks. But I have always been critical with Bezier curves and splines, these often translate badly into 3D surfaces when exporting (also between CAD systems I have noticed
Sometimes a SolidWorks file is read-in cleaner when saved as a Parasolid file (*.x_t) or when moving back in version ;)
Hi A torus and worse helix's are tricky geometries many kernels do a poor job generating them. Have you tried to play with the kernel option (COMSOL or the CAD too one ? Else is it possible to reconstruct the helix with COMSOL, you can make hybrid CAD, partly imported, partly reconstructed locally (at least that works OK for me in SolidWorks. But I have always been critical with Bezier curves and splines, these often translate badly into 3D surfaces when exporting (also between CAD systems I have noticed Sometimes a SolidWorks file is read-in cleaner when saved as a Parasolid file (*.x_t) or when moving back in version ;) -- Good luck Ivar
