Running a specific Study node using batch
I would like to run a specific Study node (suppose I have a model with 2 or more Study nodes) using batch commands. Normally I write something like
comsol -nn 8 -np 8 batch -inputfile input.mph -outputfile output.mph -batchlog batch.log
Does anyone know which additional command I should issue to be able to select a specific Study node to run?
J
3 Replies Last Post 29 sept. 2014, 22:01 UTC−4
Josh Thomas Certified Consultant
Posted: 1 decade ago 10 janv. 2013, 16:54 UTC−5
Doctor J,
Simply type:
comsol -nn 8 -np 8 batch -inputfile input.mph -outputfile output.mph -study <study tag> -batchlog batch.log
You can even specify which parameters to solve for and their values from the command line if you wanted using -pname and -plist.
Check out pgs 95 and 96 of the Installation and Operations Guide for more COMSOL Batch Commands.
Hope that helps.
Josh Thomas
AltaSim Technologies
Doctor J, Simply type: comsol -nn 8 -np 8 batch -inputfile input.mph -outputfile output.mph -study -batchlog batch.log You can even specify which parameters to solve for and their values from the command line if you wanted using -pname and -plist. Check out pgs 95 and 96 of the Installation and Operations Guide for more COMSOL Batch Commands. Hope that helps. Regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago 10 janv. 2013, 16:58 UTC−5
Oh, if you don't know the <study tag>...right-click on the main Study node and select Properties from the list. The Settings window will give you the tag. For example, std1 or std2, etc.
Josh Thomas
Oh, if you don't know the ...right-click on the main Study node and select Properties from the list. The Settings window will give you the tag. For example, std1 or std2, etc. Regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago 29 sept. 2014, 22:01 UTC−4
What if I want to get output of one node?
For example, I want to know the temperature of a node and I know the tag of this node is tag1.
What command should I type for this?
THX
Hi, What if I want to get output of one node? For example, I want to know the temperature of a node and I know the tag of this node is tag1. What command should I type for this? THX
