Reading Deformation graph
I am getting a coloured graph for deformation in microgripper.
Now I want to get the values of deformation at different point(x,y,z) (instead of graph)
please let me know how to get that in comsol.
3 Replies Last Post 7 janv. 2013, 02:24 UTC−5
Posted: 1 decade ago 2 janv. 2013, 03:29 UTC−5
3D or 2D color views are not relaay there to do measurements but to give nice views, to get a eformation, its better to use line graphs along an edge or a "data set - cut line" and ask for the displacement u,v,w or disp
In 2D views you can set contour gaph ontop or you can add the "more - minmax points" on your graph
If you are new to COMCOL its worth to play several of the video presentationson the main site, there are many trics too learn, and use the help ;) i.e. "results" video
Hi 3D or 2D color views are not relaay there to do measurements but to give nice views, to get a eformation, its better to use line graphs along an edge or a "data set - cut line" and ask for the displacement u,v,w or disp In 2D views you can set contour gaph ontop or you can add the "more - minmax points" on your graph If you are new to COMCOL its worth to play several of the video presentationson the main site, there are many trics too learn, and use the help ;) i.e. "results" video -- Good luck Ivar
Posted: 1 decade ago 7 janv. 2013, 01:04 UTC−5
Hi Ivar,
Thanks for reply....
Actually I have checked videos available on comsol website but i didnt get anything related to generate a graph or table from simulation.
please share any document or procedure regarding that.Meanwhile i will be finding out in comsol help documentation
Hi Ivar, Thanks for reply.... Actually I have checked videos available on comsol website but i didnt get anything related to generate a graph or table from simulation. please share any document or procedure regarding that.Meanwhile i will be finding out in comsol help documentation
Posted: 1 decade ago 7 janv. 2013, 02:24 UTC−5
sure you do not find your solution in one of these ?
www.comsol.eu/video/167/
www.comsol.eu/video/371/
www.comsol.eu/video/375/
www.comsol.eu/video/395/
www.comsol.eu/video/397/
www.comsol.eu/video/425/
www.comsol.eu/video/427/
Hi sure you do not find your solution in one of these ? http://www.comsol.eu/video/167/ http://www.comsol.eu/video/371/ http://www.comsol.eu/video/375/ http://www.comsol.eu/video/395/ http://www.comsol.eu/video/397/ http://www.comsol.eu/video/425/ http://www.comsol.eu/video/427/ ... -- Good luck Ivar
