Geometry Modification
Posted 9 nov. 2012, 05:29 UTC−5 Geometry Version 4.3 2 Replies
I just want to know if there is an easy way for geometry modification in comsol. For example if I have done some simulation on a plate with a hole in it, and then I want to repeat the simulation on the same plate with the hole relocated to another coordinate, can I run a journal file (like in gambit) and just change the hole coordinate in it and let comsol repeat the geometry building procedures itself?
The easiest way is to repeat everything manually with new coordinate, but it is time consuming.
Thanks a lot.
Thanks a lot.
2 Replies Last Post 9 nov. 2012, 08:21 UTC−5
