Nesting analytic functions
I am simulating heat transfer problem where I need the heat flux dependent of radius change, and the radius futher depends on time. I have defined two analytic function one for radius and other for heat flux but it always gives error that radius is unkown parameter.
Can someone please help me this through.
Bests
Ali
1 Reply Last Post 10 août 2023, 10:37 UTC−4
Posted: 1 year ago 10 août 2023, 10:37 UTC−4
Sounds like a syntax-related or other specification-related error. I suggest you post your .mph to the forum, as well as tell the readers where you think they should look (that is, where in your configuration) to better understand your problem.
