Transmit time-dependent solution with Time Space dependent Interpolation function or directly
Posted 1 nov. 2012, 14:10 UTC−4 Computational Fluid Dynamics (CFD), Materials, Parameters, Variables, & Functions, Studies & Solvers 2 Replies
Hello!
I want to use a velocity boundary solution u(x, t) from one physics in another physics. The timesteps, the mesh and the geometry are equal. I use the Laminar Two Phase Flow, level Set physics twice in COMSOL 4.3. I have red a lot of post, but I couldn't find a solution. Especially in 4.3. I followed two approaches:
1. I tried to use the dependent variable u from solution 1. With the solver notes I just can transmit one step from solution 1 to the initial conditions of solver 2. But I want the whole velocity over time used for computing. Have I done anything wrong? Is it possible to hand over the solution1 for every time step?
2. I exported the solution 1 on the boundary as a 1D Line Graph at all times as a spreadsheet. Then I changed the exported txt file to the standard COMSOL spreadsheet column1=x column2=t and column3=u(x, t) It looks like:
0 0 0.34
0.2 0 0.16
0.3 0 0.31
0 0.1 0.28
0.2 0.1 0.19
0.3 0.1 0.23
0 0.2 0.29 and so on.
Then I imported it in the definitions (I tried global and local) note as a interpolation function int1 (x, y). I defined the units. When I call the function in the physic via u(x, t) no errors occur. But in the results I can see that the function doesn't transmit time-dependent values. Maybe I've done an mistake? Does anyone know?
Which approach is the better one fpr COMSOL 4.3? Where could be the mistake?
Thanks for any help!
0 0 0.34
0.2 0 0.16
0.3 0 0.31
0 0.1 0.28
0.2 0.1 0.19
0.3 0.1 0.23
2 Replies Last Post 2 nov. 2012, 18:30 UTC−4
