Loss factor
I s it possible to calculate loss factor of a material using comsol?
3 Replies Last Post 5 juil. 2023, 07:02 UTC−4
Posted: 1 year ago 4 juil. 2023, 02:38 UTC−4
Loss factor is a material property, which must be provided to the model from a datasheet or measurements.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 1 year ago 5 juil. 2023, 04:46 UTC−4
use the PIM Method, you can calculate the loss factor
Posted: 1 year ago 5 juil. 2023, 07:02 UTC−4
PIM (Power Input Method) is an experimental method for determining the loss factor, which as Edgar says, is a material property.
However, when using the PIM method you need to know the strain energy (or the kinetic energy) of the test object. For this purpose you can use a finite element model.
Henrik Sönnerlind
COMSOL
PIM (Power Input Method) is an experimental method for determining the loss factor, which as Edgar says, is a material property. However, when using the PIM method you need to know the strain energy (or the kinetic energy) of the test object. For this purpose you can use a finite element model.
