29 oct. 2012, 16:18 UTC−4
apologies, the model was too large to attach
30 oct. 2012, 02:24 UTC−4
you should "clean up your model" before attaching them on the forum, we wold need to resolve, but that is often easier.
To clean; select Edit - Clear all solutions, Clear all mesh, File - Reset history, and Save as with new name, then upload
31 oct. 2012, 21:20 UTC−4
Ivar,
Even with your memory reducing steps I wasn't able to fit the whole model. However I was able to reduce it and now it fits, the only difference is the number of turns per coil. Hopefully now you will now be able to help me.
Regards
Eric
Ivar,
Regards
Eric
1 nov. 2012, 03:07 UTC−4
COMSOL has also "lumped" coil BC's that consider also multiturn coils, you do not get the details of the coil winding interiour, but you model solves often easier. Nevertheless, these BC's are complex physics, so read carefully the doc and try a few exercices befor using them, to really understand how they work
