charged particle tracing plot bend
Posted 16 juin 2023, 12:19 UTC−4 Charged Particle Tracing, Results & Visualization, Physics Interfaces Version 5.6 0 Replies
Hi, I built an ion bender and its magnetic field with electrostatics through stationary study. I also built the charged particle tracing with time dependent study where the particles inside are plotted. However, the particles should be bending and going to the outlet that i assigned instead of going straight to the end. I believe this should be working as the electrostatics part assigned the magnetic field so the particles should be following it, I don't know why it wouldn't. Any help will be appreciated!
Additionally, the tubes are built because I need the inside to be air and this was a solution for my geometry. And, I have tried adding magnetic force on the charged particle tracing part so I could get the particles to bend, that also didn't work.
Hello Melisa Kocak
