How to create plot
In post-processing, I use "Derived Values" to evaluate some variables at a cut point.
I would like to create a 1D plot where I evaluate an expression along a cut line, but in that expression, I would like to use my previously defined derived value as a constant. So my question is: how can I reference a derived variable in a plot expression?
1 Reply Last Post 2 juin 2023, 05:00 UTC−4
Posted: 2 years ago 2 juin 2023, 05:00 UTC−4
In the end after some trial and error I solved my problem with workaround, using a combination of whitsol and at3:
withsol('sol1', at3(0,0,0,mf.Bx))
In the end after some trial and error I solved my problem with workaround, using a combination of `whitsol` and `at3`: ``` withsol('sol1', at3(0,0,0,mf.Bx)) ```
