2 years ago
24 mai 2023, 12:03 UTC−4
By default Comsol stores the solution at each time step, where the "solution" means u,v,w for each mesh element.
I think you will find that 1E9 multiplied by the number of mesh elements multiplied by 3 is more than your hard disk size.
I suggest you explain what you are trying to do, post your model, and ask for suggestions.
By the way expecting that a time-dependent solution will neither diverge or see numerical damping for > 1e9 iterations is...very optimistic.
Jeff Hiller
COMSOL Employee
2 years ago
24 mai 2023, 13:18 UTC−4
Hello Himanshu,
To add a bit to Dave's post, you can read more on this topic in this blog post which discusses how time steps are selected by the software by default, and what options you have to override that default behavior.
Jeff Hiller
Hello Himanshu,
To add a bit to Dave's post, you can read more on this topic in [this blog post](https://www.comsol.com/blogs/automatic-time-step-and-order-selection-in-time-dependent-problems/) which discusses how time steps are selected by the software by default, and what options you have to override that default behavior.
