Dimension of a exported data array
Posted 12 oct. 2012, 14:40 UTC−4 Results & Visualization Version 4.3 2 Replies
I have two model, and I need to graph with matlab the difference. I plot with 1D graph a first model, and export the graph; then i plot with 1D graph the second model, and export the graph. My problem is : the first exported data array has dimension 2x666, the second has dimension 2x487. How I make matching the array dimension? There are a hidden option in 1 D graph?
Thank you
More info : I do this : I copy a .mph file, delete the object of the difference between the two model, and then plot and export. I don't understand why this operation change the array columns from 666 to 487
Thank you
2 Replies Last Post 16 oct. 2012, 10:39 UTC−4
