3 oct. 2012, 02:55 UTC−4
COMSOL works only in cartesian (and 2D-axi) but you can add your own coordinate systems, and many BC or domain physics properties will then propose to select the desired intput coordinate system to refer to.
But for the postprocessing everything is in cartesian, so you must type out the equations, or use your Defined coordinate system to reexpress the variables the way you want them
7 déc. 2012, 01:39 UTC−5
Hi Ivar,
Because of COMSOL works in Cartesian coordinate, so the user-defined variables have to be in Cartesian coordinate even if i am working on a half-ellipse in a 2D axi study, is it?
Thanks!
Hi Ivar,
Thanks!
7 déc. 2012, 03:00 UTC−5
I would say yes and no ;) you can define your own "Definitions" coordinate systems, but indeed you need to get down to the COMSOL coordinates at least, and back to yours in the results section
Check the equations and new variables to help you from the user defined coordinate systems
