Total y-stress on the fluid
Posted 28 sept. 2012, 08:48 UTC−4 Version 4.2a, Version 4.3 0 Replies
Total y-stress on the fluid calculated with v3.5a it is like this: v*T_y_chns ( integrate it under the "integration coupling variables"). In this case, also should select "ale frame" if the boundary is moving/deforming. the chns part is inherent from the the chemical engineering module. if you are using mems module then it is v*T_y_mmglf.
How do I do this calculation in COMSOL 4.2a or 4.3 using the Laminar Flow module?
Thanks a lot
Hello Arlindo Garcia
