Wire arc additive manufacturing
Hi!
I want to model a Wire arc additive manufacturing process but cant seem to figure out how. to need to model an additve manufactuirng process we need to add material layer by layer, i used the activation node for that but it doesnt work.in tempreature result and only shows it on volume result plus if i want to add layer on top of one i cant seem to figure out how to make the heat source go on the other layer because if i add other layer on top of one comaol wont let me apply heat on the lower one. and for some reason the activation doesnt work . i am using a gaussian moving heat source. and activation expression as x<velocity*time. can anyone help me
0 Replies Last Post 11 janv. 2023, 02:54 UTC−5
Hello sourav mahato
