Parametric sweep syntax error
I am modeling a using wave optics module and using a parametric sweep sweeping multiple parameters always gives me the following error:
Syntax error in expression.
  • expression: al, tcot
  • subexpression: , tcot
  • position 3
al and tcot are the two global parameters I am sweeping. This error is not present if I sweep only one parameter. So, to fix it I use multiple parametric sweeps, but it is not very convenient. is there any solution for this?!
0 Replies Last Post 3 déc. 2022, 03:49 UTC−5
Hello Fahmy Yousry
