3 août 2012, 05:08 UTC−4
I believe one way is to use the rotary fluid set up physics, check the model library for the examples. But normally I believe you can define a velocity for a boundary directly in the CFD, the only thing is that you need to define a cylindrical coordiante and define the rotation accordingly in the phi direction.
3 août 2012, 05:20 UTC−4
thanks for repleying
I did defined a cylindrical coordiante and defined the rotation in the phi direction but can't find a way to add a velocity to any boundary (the walls). I am only able to add a velocity to a object.
3 août 2012, 07:06 UTC−4
I'm not by my COMSOL WS so I cannot check myself, but perhaps you might add a subnode to the wall node of the type velocity, and ceck the help files. It could be that its related to some of the additional modules
Jeff Hiller
COMSOL Employee
3 août 2012, 08:33 UTC−4
See
www.comsol.com/showroom/gallery/616/
Note that to model this in 2D axi, you will need the swirl flow interface that is part of the CFD Module.
See http://www.comsol.com/showroom/gallery/616/
3 août 2012, 09:01 UTC−4
Sorry I was blind didn't look in the right place. I found what you were talking about in boundary conditions. But I don't get an option to have the moving wall condition expressed in cylindrical coordinates. Is there a way to write the x en y components as tangental velocity
3 août 2012, 09:27 UTC−4
I have found sliding wall and that was exactly what I needed. Thanks for any help!
