Error regarding meshing
hello everyone I tried to simulate model of battery with respect to thermal management and I am getting an error as mentioned below.please help me out with this.
"Failed to find a solution. Singular matrix.
There are 1821 void equations (empty rows in matrix) for the variable comp2.T. at coordinates: (0.02), (0.06), (0.06), (0.02), (0.06), ...
and similarly for the degrees of freedom (empty columns in matrix). Returned solution is not converged. Not all parameter steps returned."
1 Reply Last Post 31 janv. 2022, 15:10 UTC−5
Posted: 3 years ago 31 janv. 2022, 15:10 UTC−5
Hello Nikhil,
You may have the same problem, resolved by the same solution, as in this recent thread.
If that does not help, please post your .mph file, it'll be easier for Discussion Forum readers to help you.
Jeff Hiller
Hello Nikhil, You may have the same problem, resolved by the same solution, as in [this recent thread](https://www.comsol.com/forum/thread/301511/no-mesh-on-domains?last=2021-12-25T03:01:58Z). If that does not help, please post your .mph file, it'll be easier for Discussion Forum readers to help you. Best regards, Jeff
