3 years ago
19 janv. 2022, 03:07 UTC−5
If you pick a point like a corner on the geometry, there will be a node there. But you might be picking a point right now that is not part of the meshed geometry? You can also set up a Cut Point under Results-Datasets whose coordinates you are free to choose, and they are not necessarily going to coincide with a node.
3 years ago
19 janv. 2022, 11:48 UTC−5
Updated:
3 years ago
19 janv. 2022, 11:53 UTC−5
Rene
Thank you very much. I did successfully get some plot. How can I refer to the cut point when I use 1D point plot?
Rene
Acculution ApS
Certified Consultant
3 years ago
20 janv. 2022, 02:47 UTC−5
Rene
Change the Dataset from Study1(...) to you Cut Point solution.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
>Rene
