Boundary Condition
Seyed Mohammad Hossein Jazayeri Shoushtari
I want to use this expression as a boundary condition (pressure head) in the Richard's equation modules
Hp0=1.094-y+0.235*cos(0.0081*t)
where, t is the time and y is the vertical coordinate.
I want to use above expression whenever is positive and if it is negative put zero for Hp0.
I have tried to use 'the if operator' but it has not worked.How can I do that in the COMSOL?
Thanks in advance
Amir
2 Replies Last Post 20 juin 2012, 23:49 UTC−4
Posted: 1 decade ago 20 juin 2012, 15:42 UTC−4
have you tried the max() operator ?
Or a boolean (...)*(...>0)
but both of these have discontinuities that might well mike your solver have convergion issues
Hi have you tried the max() operator ? Or a boolean (...)*(...>0) but both of these have discontinuities that might well mike your solver have convergion issues -- Good luck Ivar
Posted: 1 decade ago 20 juin 2012, 23:49 UTC−4
Thank you for your response
yes I have tried both of them but they did not work properly.
1.094-y+0.235[m]*cos(0.0081[1/s]*t)*(y<=1.094)
OR
If ((1.094-y+0.235[m]*cos(0.0081[1/s]*t))<=0,0,(1.094-y+0.235[m]*cos(0.0081[1/s]*t))
The boundary condition is a linear function of y but when I use those operator the result is not linear (the line graph of the boundary ).
Another question is that when we turn on the gravity effects on Darcy's low or Richard's modules, the gravity effects acts as hydrostatic pressure or has other effects on the model?
The size of my model is a bit large (22Mb) and I can't attache it.
Would you please guide me to overcome this issue?
Amir
Hi Thank you for your response yes I have tried both of them but they did not work properly. 1.094-y+0.235[m]*cos(0.0081[1/s]*t)*(y
