Livelink COMSOL with MATLAB
Posted 17 août 2021, 15:21 UTC−4 0 Replies
Hi I'm working on cell scaffolds and l used Darcy and solid physics for modeling and I'm using Livelink COMSOL with MATLAB for material update (Young module) and I used the following code to set the previous solution as the initial solution .
model.sol('sol1').feature('v1').set('initmethod', 'sol'); model.sol('sol1').feature('v1').set('initsol', 'sol1');
But I got the following error: Messages:
The following feature has encountered a problem:
- Feature: Time-Dependent Solver 1 (sol1/t1)
Nonlinear solver did not converge
Maximum number of segregated iterations reached Time: 0 s. Last time step is not converged.
Also, I can not define the material in MATLAB because i got the error that you did not define the Young module, but I'm sure I defined the Young module, but by defining the material in Comsol and the command in MATLAB (model.sol('sol1').runAll), it successfully runs (only if I comment out the two lines of codes I mentioned above) Thank you for your help
Hello Hani Chi
