FSI: Moving mesh (ale) vs Moving mesh
Posted 5 mai 2021, 16:45 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Structural Mechanics Version 5.4 0 Replies
I have the doubt of which of these two options select for my FSI simulation:
-The moving mesh in: Components-Definitions-Moving mesh-Deforming Domain
-The moving mesh (ale) in: Components-Moving mesh
If I use moving mesh (ale) in the results I can only see the deformation of the boundary separating the fluid from the solid, while if I use moving mesh I can see the meshes deforming properly not only in the boundary. Is there any difference between the two? Does it impact only to the visualization?
Thank you
Hello James Hernández
