Material change during time-dependent study
I am trying to find a way, of changing the material of a domain during time. I am doing a heat transfer study, simulating the cooking of a steak. I have added two domains on either side of my steak, representing the pan and the air. I then want to swap the materials of those two domains after e.g. 60 seconds (representing the flip of the steak). Is this possible? I have done something similarly with the boundary temperatures by constructing a piecewise function, but setting the material of a domain seems to work differently.
Thank you.
1 Reply Last Post 21 avr. 2021, 16:24 UTC−4
Posted: 4 years ago 21 avr. 2021, 16:24 UTC−4
Emil,
probably the easiest way is to make the respective material properties time dependent.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Emil, probably the easiest way is to make the respective material properties time dependent. Cheers Edgar
