how to realize stent with comsol?
Hello to everybody,
I'm a student of Politecnico of Torino and i'm trying to realize a stent geometry with comsol (4.2a version).
Is there a method to realize it without using other cad as solidwork or autocad and so on?
Can someone helps me? I hope yes
I would be very happy for your help
Thanks for attention
Michele
5 Replies Last Post 24 nov. 2015, 08:37 UTC−5
Posted: 1 decade ago 15 mai 2012, 08:54 UTC−4
It should be possible with COMSOl CAD unit, if you start with a 3D tube (difference of two cylinders) and then create an extrusion ellipsoidal cylinder (or just a classical cylinder) with a radial axis that you duplicate radially 4-6 times and along the cylinder axis. then take the difference of your tube and all elpsoidal cylinders
Hi It should be possible with COMSOl CAD unit, if you start with a 3D tube (difference of two cylinders) and then create an extrusion ellipsoidal cylinder (or just a classical cylinder) with a radial axis that you duplicate radially 4-6 times and along the cylinder axis. then take the difference of your tube and all elpsoidal cylinders -- Good luck Ivar
Posted: 1 decade ago 15 mai 2012, 09:49 UTC−4
OK thank you so very much Ivar.It's could be a good solution, i'm trying just now. Only just one another question: after having built the single cylinders to realize radially in my tube , how can i duplicate radially 5-6 times my cylinder before doing difference?
Thanks so much!
OK thank you so very much Ivar.It's could be a good solution, i'm trying just now. Only just one another question: after having built the single cylinders to realize radially in my tube , how can i duplicate radially 5-6 times my cylinder before doing difference? Thanks so much!
Posted: 1 decade ago 15 mai 2012, 09:51 UTC−4
you have the copy or the move using the keep initial and you define a range or a comma separated series of values, this will duplicate it "n" times
Hi you have the copy or the move using the keep initial and you define a range or a comma separated series of values, this will duplicate it "n" times -- Good luck Ivar
Posted: 9 years ago 24 nov. 2015, 07:31 UTC−5
hi. Teach me show in video stent
Walter Frei COMSOL Employee
Posted: 9 years ago 24 nov. 2015, 08:37 UTC−5
It is also worth mentioning that the Design Module:
www.comsol.com/design-module
has extended functionality for creating complex parts. In particular, the fillet and loft functionality may be useful to you.
It is also worth mentioning that the Design Module: http://www.comsol.com/design-module has extended functionality for creating complex parts. In particular, the fillet and loft functionality may be useful to you.
