Synchronous reluctance motor
Maksim Sitnikov Doctoral Researcher
Hello! Could you tell me what the error is in the model? I set the rotating part as a rigid body with an applied torque created by the engine itself (that is, idle), but for some reason it is not synchronized in speed with the frequency of the supply voltage. A three-phase system of 1050 Hertz is connected, the engine rotation speed is 31500 rpm, but it does not reach this speed
1 Reply Last Post 16 févr. 2021, 09:27 UTC−5
Posted: 4 years ago 16 févr. 2021, 09:27 UTC−5
Maxim,
I had a brief look into your model and saw that there are many issues in the variables definitions. There may be more issues I haven't seen. Better pull all obvious errors and warnings out before you do more testing.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Maxim, I had a brief look into your model and saw that there are many issues in the variables definitions. There may be more issues I haven't seen. Better pull all obvious errors and warnings out before you do more testing. Cheers Edgar
