Thermal Expansion Layered Shell - Composite Vs Aluminum
Posted 31 déc. 2020, 19:41 UTC−5 Heat Transfer & Phase Change, Structural Mechanics Version 5.6 1 Reply
I'm trying to simulate the thermal expansion of a thin plate illuminated by Laser with two different materials; plate-1: CFRP composite, plate-2: Aluminum clad panel. I'm using "Layered Shell" interface with "Heat transfer in Shells" interface and the Multiphysics coupling of "Layered Thermal Expansion".
For plate-1: CFRP composite panel, the simulation works fine and shows both the Von-Mises stresses and Temperature distribution in the panel.
However, for plate-2: Aluminum Clad panel, the simulation only runs for Heat Transfer interface and shows only Temperature distribution and doesn't show Von-Mises stresses. It doesn't give any error or warning.
Both the model files are attached here (files are of version 5.6). Kindly help me out with this query.
Note: files were very large in size to be uploaded here. Therefore, all the mesh and solutions are cleared to reduce the file size.
