How to specify different boundaries in an equation
There are two boundaries in my model: Boundary A and Boundary B. Boundary A is located at x = 0 cm, while Boundary B is located x = 2 cm. There is an equation which is a boundary condition:
-q*(∇u2) = 1.5* (u(A)-u5(B)-E(B))/(q*R)
Where A and B refer to Boundary A and Boundary B. u, u2 and u5 are the electric potential of electrons, iodide ions and the electrostatic potential, respectively.
My question is: how do I specify these two boundaries in this equation of boundary condition? How do I tell the computer that I want to use the value of u at Boundary A and the values of u5 and E at boundary B? I try to type this as the "g" value of the Neumann boundary condition:
1.5* (u(x=0)-u5(x=2)-E(x=2))/(q*R)
but it doesn't work.
Thank you!
5 Replies Last Post 16 nov. 2013, 18:22 UTC−5
Posted: 1 decade ago 31 mars 2012, 14:17 UTC−4
I havnt really read if you are in 1D or 2D, but if its 1D you should make a global variable out of your dependent values t the different boundaries, then you can refer to tem ynwhere, else you need the coupling projection operators to map the results at one location to another, check the doc.
do not forget that dependent vriables are in fact fields u(x,y,z) so you need to refer to thes eimplicit locations via the selections
Hi I havnt really read if you are in 1D or 2D, but if its 1D you should make a global variable out of your dependent values t the different boundaries, then you can refer to tem ynwhere, else you need the coupling projection operators to map the results at one location to another, check the doc. do not forget that dependent vriables are in fact fields u(x,y,z) so you need to refer to thes eimplicit locations via the selections -- Good luck Ivar
Posted: 1 decade ago 1 avr. 2012, 23:15 UTC−4
Hi Ivar,
It is a 3-D model. But only the direction along X axis matters. Thanks
Hi Ivar, It is a 3-D model. But only the direction along X axis matters. Thanks
Posted: 1 decade ago 2 avr. 2012, 22:31 UTC−4
Hi Ivar,
Thank you very much for your answer. Can you explain it a little more? I'm really new to Comsol...
Hi Ivar, Thank you very much for your answer. Can you explain it a little more? I'm really new to Comsol...
Posted: 1 decade ago 15 nov. 2013, 13:58 UTC−5
Hi Ray,
Did you fix your problem?
I have the same problem and I can't figure it out.
Thanks.
Marco
Hi Ray, Did you fix your problem? I have the same problem and I can't figure it out. Thanks. Marco
Posted: 1 decade ago 16 nov. 2013, 18:22 UTC−5
In the physics portion of the model tree, right click on the boundary section, look for the boundary condition you want to specify, insert the boundary number corresponding to the location where you want it to be. It is intuitive.
