parametric study
Pavan Kumar Penumakala
hi..
lf i want to study the effect of the parameter ..say V.. this parameter changes from 1 to 10 m/s...
and i want to plot temperature vs time plot for all the case..how i can proceed..?
3 Replies Last Post 30 mars 2012, 13:47 UTC−4
Posted: 1 decade ago 30 mars 2012, 09:47 UTC−4
Just select all the parameter values you want to plot the curves for.
Posted: 1 decade ago 30 mars 2012, 09:53 UTC−4
hi..in the time dependent heat study,i used in the global paremetre section V=5x and in the time dependent study i select the parametric sweep and sweeping x = 1:1:5
in the 1D point graph ...i am unable to plot Temperature Vs time for all x=1:1:5
hi..in the time dependent heat study,i used in the global paremetre section V=5x and in the time dependent study i select the parametric sweep and sweeping x = 1:1:5 in the 1D point graph ...i am unable to plot Temperature Vs time for all x=1:1:5
Posted: 1 decade ago 30 mars 2012, 13:47 UTC−4
are you sure your derived variabble or plot node is pointing to the correct data set ? When you do a sweep, you get 2 Data set, one for the current (last) solver case and one with all the parametrised data matrices
Hi are you sure your derived variabble or plot node is pointing to the correct data set ? When you do a sweep, you get 2 Data set, one for the current (last) solver case and one with all the parametrised data matrices -- Good luck Ivar
