RF frequency domain scattering electric field module- normalization of scattered field Ex by the background field Ebx
I am uncertain if I am incorrect in my assumption, so I have come here hoping someone can clarify for me.
emw.Ex -displays the scattered electric field
emw.Ebx -is initial background electric field used for solving the problem
I want to normalize (emw.Ex/emw.Ebx) to see the enhancement. I am plotting on a cross section where emw.Ebx is almost a constant value at this height (~0.26 V/m).
When I plot (emw.Ex/emw.Ebx) vs when I plot (emw.Ex/0.26) where 0.26 is the value of emw.Ebx at this cross section, I get two different plots.
Is (emw.Ex/emw.Ebx) the proper way to plot this enhancement?
Maybe I am interpreting emw.Ex or emw.Ebx incorrectly.
Thank you,
Brandon
7 Replies Last Post 21 juil. 2013, 21:42 UTC−4
Posted: 1 decade ago 27 mars 2012, 17:36 UTC−4
emw.Ex is the total field. Scattered field is (emw.Ex-emw.Ebx)
Posted: 1 decade ago 27 mars 2012, 17:42 UTC−4
So to normalize to see enhancement, I would need:
(emw.Ex-emw.Ebx)/(emw.Ebx)
Based on your response is this the correct formulation
So to normalize to see enhancement, I would need: (emw.Ex-emw.Ebx)/(emw.Ebx) Based on your response is this the correct formulation
Posted: 1 decade ago 27 mars 2012, 18:06 UTC−4
It depends what you mean by "enhancement" :)
In my case, I use the following quantity integral(abs(Escattered)^2)/integral(abs(Ebackground)^2).
It depends what you mean by "enhancement" :) In my case, I use the following quantity integral(abs(Escattered)^2)/integral(abs(Ebackground)^2).
Posted: 1 decade ago 27 mars 2012, 18:26 UTC−4
Well I can clarify. I am dealing with an electric field being incident into a metal nanoantenna cavity from a substrate. So there is amplification of the electric field due to local surface plasmons, which increases the amplitude of my electric field in the cavity. I am trying to normalized the scattered field by the background incident field to get a sense of this quantity.
This is something like (|Ecav|/|Esig|)^2 which I believe is an enhancement factor.
So I was assuming Ecav/Esig was something like emw.Ex/emw.Ebx.
I am to give your expression a try.
In your expression is Escattered= (emw.Ex-emw.Ebx)
and Ebackground = emw.Ebx
I am not sure how to do the integration on my 2-D surface plot but that is a separate issue.
Well I can clarify. I am dealing with an electric field being incident into a metal nanoantenna cavity from a substrate. So there is amplification of the electric field due to local surface plasmons, which increases the amplitude of my electric field in the cavity. I am trying to normalized the scattered field by the background incident field to get a sense of this quantity. This is something like (|Ecav|/|Esig|)^2 which I believe is an enhancement factor. So I was assuming Ecav/Esig was something like emw.Ex/emw.Ebx. I am to give your expression a try. In your expression is Escattered= (emw.Ex-emw.Ebx) and Ebackground = emw.Ebx I am not sure how to do the integration on my 2-D surface plot but that is a separate issue.
Posted: 1 decade ago 27 mars 2012, 20:46 UTC−4
That's an easy part. Define integration operator on your domain (Definition-Model Couplings-Integration). Then in post-processing use intop1(abs(field)) to get the value of integral.
This way you can define amplification inside the entire cavity. I don't think the amplification at particular points of the cavity has much meaning.
[QUOTE] I am not sure how to do the integration on my 2-D surface plot but that is a separate issue. [/QUOTE] That's an easy part. Define integration operator on your domain (Definition-Model Couplings-Integration). Then in post-processing use intop1(abs(field)) to get the value of integral. This way you can define amplification inside the entire cavity. I don't think the amplification at particular points of the cavity has much meaning.
Posted: 1 decade ago 16 mai 2013, 13:50 UTC−4
Could someone clarify how to specify the face where the background electric field is incident on the system?
I have an air block with spherical scatterers embedded in it. The background E field needs to be incident on one of the faces of the cube, and I need to study the fields within the block. I am using scattering boundary condition for all the faces of the block.
Could someone clarify how to specify the face where the background electric field is incident on the system? I have an air block with spherical scatterers embedded in it. The background E field needs to be incident on one of the faces of the cube, and I need to study the fields within the block. I am using scattering boundary condition for all the faces of the block.
Posted: 1 decade ago 21 juil. 2013, 21:42 UTC−4
The same question.
Thanks in advance.
The same question. Thanks in advance.
