How to set boundary conditions that involve two boundaries?
There are two boundary conditions in my model:
-q*(gradient u2) = 1.5*(q*u(anode)-q*u5(cathode)-E(cathode))
-q*(gradient u3) = -0.5*(q*u(anode)-q*u5(cathode)-E(cathode))
where anode and cathode are two boundaries in different positions along the Y axis. (anode is at -1.5 cm along axis Y, cathode is at 1.5 cm along axis Y).
Basically I need to use the conditions of two boundaries in the above equations. How can I realize that?
Thank you
4 Replies Last Post 17 juin 2012, 16:31 UTC−4
Posted: 1 decade ago 20 mars 2012, 16:19 UTC−4
I would say cut your boundary in two with a point, line or surface, or add a sign(y)* condition to change for y<0, repectively >0
Hi I would say cut your boundary in two with a point, line or surface, or add a sign(y)* condition to change for y0 -- Good luck Ivar
Posted: 1 decade ago 20 mars 2012, 20:44 UTC−4
Sorry I'm quite confused. Could you explain it a little, please?
Cutting the boundary is impossible since they are two different boundaries, one is located at -1.5 cm along axis Y, and the other at 1.5 cm along Y. Thanks, Ivar!
Sorry I'm quite confused. Could you explain it a little, please? Cutting the boundary is impossible since they are two different boundaries, one is located at -1.5 cm along axis Y, and the other at 1.5 cm along Y. Thanks, Ivar!
Posted: 1 decade ago 21 mars 2012, 02:13 UTC−4
my turn to be sorry, as I must have missed your question ;)
It would be easier to understand if you upload a simple model, I'm woundering if the issue is not about the variable / field default notation of COMSOL, that played me many games and a lot of confusion before I got it right
Hi my turn to be sorry, as I must have missed your question ;) It would be easier to understand if you upload a simple model, I'm woundering if the issue is not about the variable / field default notation of COMSOL, that played me many games and a lot of confusion before I got it right -- Good luck Ivar
Posted: 1 decade ago 17 juin 2012, 16:31 UTC−4
Iam having problem in setting the boundary condition for the 3d generator.
please help me with this
thank you
Hi, Iam having problem in setting the boundary condition for the 3d generator. please help me with this thank you
