Hello Shahriar Khushrushahi
19 janv. 2012, 15:53 UTC−5
I have the same problem, could you find any answer for pressure point condition?
Giti
Giti
19 janv. 2012, 18:35 UTC−5
It was a long time ago, and I dont remember how I resolved it. I think it shouldnt matter what the pressure is set at any point because the solution will just scale relative to that initial set pressure.
19 janv. 2012, 19:04 UTC−5
20 janv. 2012, 02:02 UTC−5
as for all physics one need to sett get dependent variables defined fully, in FCD the pressure is often a relative or gauge pressure, and the results are correct for any value + a constant at some time one need to fix this constant and if a p=o output BC is not used, and setting a "p=0" at one point within the fluid domain might be enough to define the constant (=0 in this case)
24 oct. 2012, 07:16 UTC−4
Hi Shahriar Khushrushahi,
i know it was a very long time ago.
could you send me the latest modell about ferromagnetic fluid. Or maybe the modell that has been presented on comsol converece on 2011 with title "Planar Geometry Ferrofluid Flows in Spatially Uniform Sinusoidally Time-varying Magnetic
Fields"
i'm trying to going into these theme but it's very complex.
thank you
best regards
hidayat
Fields"
thank you
best regards
hidayat
24 oct. 2012, 17:45 UTC−4
The file was already attached in the first thread of mine
Fields"
thank you
best regards
hidayat
[QUOTE]
Fields"
thank you
best regards
hidayat
[/QUOTE]
