Transport of Dilute Species coupled to laminar flow
I am trying to couple the transport of dilute species and the laminar flow modules. However, I receive an error every time I try to sole for the dilute species (study 2 in my model).
What am I doing wrong?
Attached is the model file.
Thanks!
MRW
5 Replies Last Post 17 juin 2012, 13:14 UTC−4
Posted: 1 decade ago 15 févr. 2012, 14:50 UTC−5
Hi!
Study 2 should have some solved value for flow. Now it is using initial expression. Change Solver 2 => Dependent Variables => Method => Initial expression to solution and select Solution to Solver 1.
Best regards
Tero
Hi! Study 2 should have some solved value for flow. Now it is using initial expression. Change Solver 2 => Dependent Variables => Method => Initial expression to solution and select Solution to Solver 1. Best regards Tero
Posted: 1 decade ago 15 févr. 2012, 16:06 UTC−5
Hi Tero,
That worked, thank you.
Do you know if there is a way to change the properties of the dilute species?
Thanks!
MRW
Hi Tero, That worked, thank you. Do you know if there is a way to change the properties of the dilute species? Thanks! MRW
Posted: 1 decade ago 16 févr. 2012, 11:35 UTC−5
Hi!
What do you mean by changing properties? Changing bulk material or diffusion?
Br Tero
Hi! What do you mean by changing properties? Changing bulk material or diffusion? Br Tero
Posted: 1 decade ago 17 févr. 2012, 09:46 UTC−5
I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics.
Thanks!!
I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics. Thanks!!
Posted: 1 decade ago 17 juin 2012, 13:14 UTC−4
The diffusion coefficient (D) is the only parameter that you can change. Please try it. I also do some research on this aspect. I am also a new one....
Thanks!!
The diffusion coefficient (D) is the only parameter that you can change. Please try it. I also do some research on this aspect. I am also a new one.... [QUOTE] I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics. Thanks!! [/QUOTE]
