Step 1 results as initial values for step 2?
Posted 10 févr. 2012, 04:25 UTC−5 3 Replies
I have the following problem:
A study with two time dependent steps:
step 1: the hydrostatic Navier-Stokes equation is solved for pressure variable p0
step 2: the full Navier-Stokes equation is solved for variables u,v,w,p. How do I initialize the pressure field p with p0?
i.e. I have defined two distinct equations in variables p0 and u,v,w,p respectively.
If I try the following for 'Dependent Variables 2' of step 2, COMSOL still calculates its own (incorrect) initial values at the beginning of step 2.
img40.imageshack.us/img40/5387/dependentvariables.png
Btw, 'Step 1 saved' solution is a save solution object that stores the solution of step 1. In the 'Initial values' object of the full NS equation, I have put p=p0 as initial value.
Any help would be greatly appreciated!
3 Replies Last Post 3 juil. 2014, 04:28 UTC−4
