27 janv. 2012, 14:50 UTC−5
One way would be to say the air pressure does not deform a lot your rotating part, and that this deformation will not have any major influence on your air pressure.
Ten you can calculate the pressure from a CFD moel with rotating elements, and perform separately a structural analysis by using the precalculated pressure as boundary loading.
But I would then also suggest to add the roational centrifugal body force from the rotation speed, as I suspect this force could be stronger and would also change the shape and stress level seen by the fan blades
27 janv. 2012, 14:57 UTC−5
Hi Ivar,
Thank you for your reply!
My problem is the fan should be rotated by the air pressure instead of a given rpm, how can I do it and which model I should used?
Is there any example or tutorials?
Thank you for your help!
Hi Ivar,
27 janv. 2012, 15:06 UTC−5
even if it is the air that defines the rpm speed, you still can analyse that from your cfd model, and then apply pressure load and pm speed to a separate solid analysis.
A fully coupled rotating FSI model is still possible but far more complex to set up and to solve, and I suppose you must "hand knit" it by your own, I do not know of one such pre-cooked physics
There are at least one fan model around, not sure if its in the library or on the main web site (I'm not by my COMSOL WS so I cannot search it up)
27 janv. 2012, 15:59 UTC−5
Thank you, it is really helpful
