RE: Boundary Conditions with Weak Form PDE's
Hello Jose,
This blog post shows how to implement a transient diffusion equation in the weak form, including how to handle boundary conditions.
Jeff Hiller
1 Reply Last Post 13 mars 2020, 18:39 UTC−4
Jose Mechanical Engineering
Posted: 5 years ago 13 mars 2020, 18:39 UTC−4
Updated: 5 years ago 13 mars 2020, 18:39 UTC−4
Hello!
Quick question, when I make the weak form of my PDE, I end up with domain and surface integrals.
Do I input both types of integrals in the same spot? Are the surface integrals like using boundary conditions? If so, can I not put in the surface integrals and use the built in boundary conditions in comsol instead, like Periodic?
I'm attempting to solve a 2D transient diffusion problem.
Thank you for you help!
Hello! Quick question, when I make the weak form of my PDE, I end up with domain and _surface_ integrals. Do I input both types of integrals in the same spot? Are the surface integrals like using boundary conditions? If so, can I not put in the surface integrals and use the built in boundary conditions in comsol instead, like Periodic? I'm attempting to solve a 2D transient diffusion problem. Thank you for you help!
