ht_pem
Posted 12 janv. 2012, 18:40 UTC−5 Battery Design, Studies & Solvers Version 4.2 1 Reply
I am new to comsol 4.2 and I started with the built in model of ht_pem in the model library.
It seems that changing the dimension of this model (L) to make the channel longer result in a problem for solver that can not evaluate some of parameters.
I have no idea why such a change result in this error so any comments is appreciated.
Failed to find a solution for all parameters,even when using the minimum parameter step.
Segregated group 3
Attempt to evaluate negative power of zero.
Function: ^
Siamak
Segregated group 3
Function: ^
Siamak
1 Reply Last Post 11 févr. 2012, 08:58 UTC−5
