Henrik Sönnerlind
        COMSOL Employee
                                6 years ago
                                3 mars 2020, 11:31 UTC−5
                                                    What is that is driving the Prescribed Normal Mesh Velocity? Is it just some function of time, or is an expression computed during the solution? In the latter case, is it something from the Solid Mechanics interface?
    Henrik Sönnerlind
COMSOL
                            What is that is driving the **Prescribed Normal Mesh Velocity**? Is it just some function of time, or is an expression computed during the solution? In the latter case, is it something from the Solid Mechanics interface?
                                6 years ago
                                3 mars 2020, 14:40 UTC−5
                                                    Thanks for reply.
Appreciate your timely response.
I have an elastic solid body; a small portion of its surface is acted upon by an external load (time dependent). This causes elastic deformation in body. When deformation in body exceeds certain amount and a spacific mathematical expression is setisfied, a particular edge in the domain is displaced by using Prescribed Normal Mesh Velocity. This process keep continue, till we achieve final deformation state.
In short Prescribed Normal Mesh Velocity is drivin by an expression computed during the solution, based upon Solid Mechanics interface.
Each point of the moving edge has different velocity, depending upon its relative position from centre. For first few steps, the movement of the edge is quite smooth, but after that we observe small irregularities in smoothness of the edge. This irregularity keeps on increasing with each step and finally we get distorted edge.
Regards
A P
                            Thanks for reply.
I have an elastic solid body; a small portion of its surface is acted upon by an external load (time dependent). This causes elastic deformation in body. When deformation in body exceeds certain amount and a spacific mathematical expression is setisfied, a particular edge in the domain is displaced by using **Prescribed Normal Mesh Velocity**. This process keep continue, till we achieve final deformation state.
In short **Prescribed Normal Mesh Velocity** is drivin by an expression computed during the solution, based upon Solid Mechanics interface.
Regards
A P
