Rigid connector for applying load
I am trying to apply a force on a solid body from a point that is some distance from the body by using Rigid connector. I have a surface on the body and I made a Point in the space and I try to make a Rigid connector from the surface and the point. It does't work, I am not able to select the point, only the surface. Can someone help me with that? Am I using the right aproch for this?
Ofir
2 Replies Last Post 29 oct. 2019, 09:42 UTC−4
Posted: 5 years ago 28 oct. 2019, 06:20 UTC−4
Updated: 5 years ago 28 oct. 2019, 02:20 UTC−4
In the Applied Force subnode under Rigid Connector, you enter the coordinates of where the fore acts, rather than providing a geometrical point.
Henrik
Henrik Sönnerlind
COMSOL
Hi, In the **Applied Force** subnode under **Rigid Connector**, you enter the coordinates of where the fore acts, rather than providing a geometrical point. Regards, Henrik
Posted: 5 years ago 29 oct. 2019, 09:42 UTC−4
Hi Henrik
It works!
Thank you very mach!
Ofir
Hi Henrik It works! Thank you very mach! Ofir
