How to export nodes' coordinates and nodes' displacements data?
I'm running the eign-frequency analysis of a small membrane in structural mechanics module. After the simulation, the membrane gets deformed. Right now I wanna export the data including the nodes' coordinates in X,Y,Z axes and the displacements of these nodes in X,Y,Z axes also. How can I do that?
I'm using the version 4.2 and I choose "export->data". The file only shows data in X,Y,Z, and I've no idea what the data is?
Lu
2 Replies Last Post 17 nov. 2011, 12:50 UTC−5
Posted: 1 decade ago 17 nov. 2011, 11:51 UTC−5
I have these questions because I wanna export data to matlab and do postprocessing. I wanna plot the original shape of this membrane and the shape of the deformed membrane. And also I wanna plot the decompositions of the deformations in X,Y,Z axes.
Liu
I have these questions because I wanna export data to matlab and do postprocessing. I wanna plot the original shape of this membrane and the shape of the deformed membrane. And also I wanna plot the decompositions of the deformations in X,Y,Z axes. Thanks, Liu
Posted: 1 decade ago 17 nov. 2011, 12:50 UTC−5
with livelink to matlab yo can export all or part of the data directly to matlab, see the appropriate doc, you can also export part of a data Set, or 1-3D plot values ito csv fles. read carefully the doc, try an indexed search on the doc, or via the help file. There are many examples on the forum too, thry a search there too
Hi with livelink to matlab yo can export all or part of the data directly to matlab, see the appropriate doc, you can also export part of a data Set, or 1-3D plot values ito csv fles. read carefully the doc, try an indexed search on the doc, or via the help file. There are many examples on the forum too, thry a search there too -- Good luck Ivar
