Edges are too close in 2D domain
Hi, I have some troubles while defining 3D geometry from 2D work plane.
The error message was "Edges are too close in 2D domain"
and it was from "Form Union" section.
Would you please help?
2 Replies Last Post 12 sept. 2013, 11:07 UTC−4
Posted: 1 decade ago 16 nov. 2011, 10:41 UTC−5
check the "relative repair tolerance" tab in the "geometry" window, I cannt find back the second tolerance dimension, perhaps it has disappeared, not being used, in the new 4.2a ;)
Hi check the "relative repair tolerance" tab in the "geometry" window, I cannt find back the second tolerance dimension, perhaps it has disappeared, not being used, in the new 4.2a ;) -- Good luck Ivar
Posted: 1 decade ago 12 sept. 2013, 11:07 UTC−4
