Who has Comsol model of the Modeling Hysteresis Effects
HI everyone,
I have a tutorial on Modeling Hysteresis Effects (in Comsol 3.5). Currently, I need this model for reference of hysteresis loss analysis. Anyone who has this please share the model here?
Thank you so much.
6 Replies Last Post 4 juin 2013, 06:17 UTC−4
Posted: 1 decade ago 14 nov. 2011, 23:24 UTC−5
I am looking forward answer for ur question:)... I have a model to develop which involves Thermal hysteresis. well i have a function which has different values along heating(temp rise) and cooling(temp drop). I would obtain temp from pde model so i need to relate it with equations to model it .
Posted: 1 decade ago 15 nov. 2011, 03:51 UTC−5
I would advise to direct this question to the COMSOL support. They should be able to give you the model.
Cheers Edgar
I would advise to direct this question to the COMSOL support. They should be able to give you the model. Cheers Edgar
Posted: 1 decade ago 5 mai 2013, 09:50 UTC−4
HI everyone,
Thank you so much.
Hi Phan Van Tung!
You are from Vietnam? If possiple, could you send me your email? We could exchange some information about the Comsol or not?
Thanks.
Vo Hoang Bach
[QUOTE] HI everyone, I have a tutorial on Modeling Hysteresis Effects (in Comsol 3.5). Currently, I need this model for reference of hysteresis loss analysis. Anyone who has this please share the model here? Thank you so much. [/QUOTE] Hi Phan Van Tung! You are from Vietnam? If possiple, could you send me your email? We could exchange some information about the Comsol or not? Thanks. Best regards, Vo Hoang Bach
Posted: 1 decade ago 6 mai 2013, 04:20 UTC−4
The document you uploaded seems not be able to be solved in COMSOL 3.5a, and it mainly about the Jiles-Atherton method used to describe the hysteresis phenomenon.
I recommend you to try the two examples in AC/DC Module/ Motors and Actuators, they are "generator 2d" and "generator 3d", which deal with the interpolated B-H relationships.
In these models, only soft iron(without losses) is used. You may replace that material with the soft iron(with losses).
Good luck.
The document you uploaded seems not be able to be solved in COMSOL 3.5a, and it mainly about the Jiles-Atherton method used to describe the hysteresis phenomenon. I recommend you to try the two examples in AC/DC Module/ Motors and Actuators, they are "generator 2d" and "generator 3d", which deal with the interpolated B-H relationships. In these models, only soft iron(without losses) is used. You may replace that material with the soft iron(with losses). Good luck.
Posted: 1 decade ago 8 mai 2013, 07:34 UTC−4
hi,
www.comsol.com/community/forums/general/thread/18952
it still unsolved issue
hi, http://www.comsol.com/community/forums/general/thread/18952 it still unsolved issue
Posted: 1 decade ago 4 juin 2013, 06:17 UTC−4
the following topic maybe useful for you
www.comsol.de/community/forums/general/thread/36970/
the following topic maybe useful for you http://www.comsol.de/community/forums/general/thread/36970/
