8 nov. 2011, 03:30 UTC−5
what exactly is wrong no I do not see, but definitively it crashes
You should send it to support, so they can find out, COMSOL should crash like that, even if you have missed something important, in my opinion
8 nov. 2011, 05:09 UTC−5
It seems to work on 4.2a update 1, which was released today. See Help->Check for updates for instructions.
Niklas
Niklas
24 nov. 2011, 06:42 UTC−5
hello
I have experimental data from a biaxial experiment, where we have measured the strains on the surface of the martial out of our sample. I want to fit my model to this measured values via least-squares fitting . and using the optimization module to determine the optimum martial property for Orthotropic plane stress martial such as elastic modulus and shear modulus . It's not a time-dependent problem. i could not found in the documentation how to do this in COMSOL 4.2 optimization module. Can you tell how to define this problem in comsol or can you give some similar example problems which helps me to solve my optimization problems. thank you !
Regards
hello
Regards
24 nov. 2011, 07:04 UTC−5
I know that there is an introduction available in the documentation for the Optimization Module (at least in COMSOL 4.2a). It's about fitting two parameters that define a nonlinear material model (Mooney-Rivlin). In the tutorial the SNOPT-Algorithm is used to minimize the least-squares error and it's a stationary problem. So maybe this introduction is helpful for you.
Johannes
Johannes
