Eddy Currents in a moving cylinder
Posted 26 oct. 2011, 14:00 UTC−4 Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 3.5a 2 Replies
I'm doing a small project in Comsol 3.5a. I have a cylinder made of a
dielectric in a DC magnetic field. The circular base of the cylinder is
parallel with the direction of the magnetic field (the base is on the X-Y
plane and extruded into the plane Z while the field is along the X axis).
I want the cylinder to rotate a fixed angle along the Z axis in the field
and calculate the power loss due to eddy currents in the field. The eddy
current examples I found were all static with and AC field. I need find a
way to either A. combine the AC/DC module with the structural model (for
the rotation) or B. rotate the magnetic field (over a given time) in the
AC/DC module. I haven't found a tutorial that allows me to rotate the field
or combine modules.
My lab has physically built these parts, so we have experimental values
for the time of rotation inside the magnetic field.
The ultimate goal of this model is so we can calculate eddy currents. I
want to input the rotation time (experimentally measured in the field) and
determine the power dissipated with in various DC fields.
or combine modules.
2 Replies Last Post 28 oct. 2011, 02:59 UTC−4
