Modeling Shape Memory Effect
Dear Comsolers,
I am analyzing the bending of a shape memory alloy beam. For modeling the shape memory effect I am using the SME physic from COMSOL 5.3a ( the Lagoudas model). First a moment is applied and after the unloading process the heating starts. The heating is with a temperature above Af for complete shape recovery. But I encounter a problem with the magnitude of the moment. The study solves only for small moments for which the material does not transform to martensite. For greater moments I receive an error that the computed plastic multiplier is negative. Does anyone have an idea what could be the problem and how to be able to increase the load without receiving the aforementioned errors?
Thank you in advance.
Jovana Jovanova
1 Reply Last Post 17 mai 2019, 11:39 UTC−4
Posted: 6 years ago 17 mai 2019, 11:39 UTC−4
Updated: 6 years ago 17 mai 2019, 11:40 UTC−4
I encountered the same problem. I have tried different loading pressure range. The "The computed plastic multiplier is negative." error is still there. But the moment magnitute is different.
Did you solve this problem yet?
Yao Xu
I encountered the same problem. I have tried different loading pressure range. The "The computed plastic multiplier is negative." error is still there. But the moment magnitute is different. Did you solve this problem yet? Best, Yao Xu
