subdomain and boundary integration
I working on design of microejector with Comsol. The conditions I use, are stated below;
Space Diemension : 3D
COMSOL Application Modes
Fluid Dynamics
Incompressible Navier Stokes
Steady State Analysis
I would like to use subdomain integration and boundary integration properties of post processing. Bıt I couldn't understand the formula of these integration. For example, the unit of subdomain integration of velocity field m^4/s, I could find how this unit is calculated and where can I use this result.
I will be very pleased if somebody could explain the aim of these integrations and the answer of my questions.
Thanks in advance
Leman Güler
3 Replies Last Post 12 juil. 2012, 13:56 UTC−4
Posted: 1 decade ago 19 oct. 2011, 07:52 UTC−4
The dimension is m^4/s because it is the product of linear velocity v (m/s) and volume element dV (m^3). It is naturally not a very meaningful quantity, but if you do boundary integration of the velocity field, you'll get the volume flow rate across that boundary, which is meaningful.
dV/dt = int(v*dA)
In electrochemistry, current distribution across an electrode quite often is uneven. Then you have to integrate over the electrode to obtain the total current, which is the measured quantity.
The dimension is m^4/s because it is the product of linear velocity v (m/s) and volume element dV (m^3). It is naturally not a very meaningful quantity, but if you do boundary integration of the velocity field, you'll get the volume flow rate across that boundary, which is meaningful. dV/dt = int(v*dA) In electrochemistry, current distribution across an electrode quite often is uneven. Then you have to integrate over the electrode to obtain the total current, which is the measured quantity.
Posted: 1 decade ago 19 oct. 2011, 08:57 UTC−4
indeed do not forget the dimension of the dx*dy*dz (or dx*dy in 2D) think it over if it is the (weighted) average or the integration value you need, the first one is already divided by the total volume / respective area
Hi indeed do not forget the dimension of the dx*dy*dz (or dx*dy in 2D) think it over if it is the (weighted) average or the integration value you need, the first one is already divided by the total volume / respective area -- Good luck Ivar
Posted: 1 decade ago 12 juil. 2012, 13:56 UTC−4
If all the velocity field vectors point in the negative direction in a region, will the subdomain integration of the velocity field in that region be negative?
Also, could I use subdomain integration of the velocity field to calculate the net fluid flux passing through the region at a given instant of time?
If all the velocity field vectors point in the negative direction in a region, will the subdomain integration of the velocity field in that region be negative? Also, could I use subdomain integration of the velocity field to calculate the net fluid flux passing through the region at a given instant of time?
