1 oct. 2011, 05:01 UTC−4
why cant you use COMSOl for everything ? thta is what the math part of COMSOL is all about, no ? solving means square optimisation problems
Add a general equation dependent on your variable to be optimised define possibly a weak condition too, ensure initial conditins are OK and if possible a derivative and off you go
1 oct. 2011, 11:08 UTC−4
thank you Ivar it seems that you are right . thanks for your time very much
Best regard
Siamak B
Best regard
Siamak B
1 oct. 2011, 13:10 UTC−4
Hi again
I countered a problem during my modeling how I will include experimental data to comsol.
Hi again
2 oct. 2011, 09:54 UTC−4
experimental data can be entered as a "Definition Function", either with an interpolation or a piecewise function, the former has a derivative that helps the solver to not to get stuck on the steps
2 oct. 2011, 14:02 UTC−4
I thank you very much for what you are doing you are life saver I am working on it. But as matter of curiosity . Is there a way to update boundary condition as matlab variable in a 'for' loop. The boundary condition is like 'p*sin t '
which 'p' up to dates in a loop it will be fun to compare to results.
thanks
thanks
2 oct. 2011, 17:01 UTC−4
normally your boundary conditions can also be driven by equations, so long i's mathematically correct without circular loops
3 oct. 2011, 01:45 UTC−4
I appreciate your answer again however I want to define P as a variable that changes during each loop when I'm doing that it gives me error.
thank you
thank you
