3D Simulation
Hi, first of all excuse my bad english.
I want to view the electromagnetic field (in particular the norm of E) in the core of 3D fiber model. Through the Boundary Mode Analysis 1, 2 and Frequency Domain of the RF Module, I got the result of some data.
I could not look for the states of progress of the complete Electric Field(or lightwave) like the attached jpg file.
I thought that I properly set up two ports(Numeric). Why did this result come about?
I appreciate your review, I also attach a mph file(ver. 4.0a).
2 Replies Last Post 21 janv. 2014, 10:49 UTC−5
Hello Yong Soo Kim
Posted: 1 decade ago 12 avr. 2012, 12:45 UTC−4
Hi Yong,
I have the same problem as you had. I have challenged with my structure for several days, but I have not yet found how to deal with.
I'll appreciate it if you could share your structure (or send it to my email) if you have solved it.
ahajebi2000@gmail.com
Thank you in advance.
Akram
Hi Yong, I have the same problem as you had. I have challenged with my structure for several days, but I have not yet found how to deal with. I'll appreciate it if you could share your structure (or send it to my email) if you have solved it. ahajebi2000@gmail.com Thank you in advance. Akram
Posted: 1 decade ago 21 janv. 2014, 10:49 UTC−5
HI Akram,
Have you solved this model yet? I am seeing some kind of electric field distribution but it does not propagate through the fiber (it "fades away" immediately after the input port).
If you have a solved model that you are willing to share, or any advice would be much appreciated.
Dennis
HI Akram, Have you solved this model yet? I am seeing some kind of electric field distribution but it does not propagate through the fiber (it "fades away" immediately after the input port). If you have a solved model that you are willing to share, or any advice would be much appreciated. Thanks, Dennis
