Inverted mesh element near coordinates.
There was warning messages (ALE simulation) :
Inverted mesh element near coordinates (1.94001e-006, -1.45013e-008).
and also ,
The solver did not converge
the error message was
Singular matrix.
Is there any predictable boundary condition problems?
Thank you
1 Reply Last Post 7 sept. 2011, 10:47 UTC−4
Posted: 1 decade ago 7 sept. 2011, 10:47 UTC−4
check (search) the forum there are many discussions around those points. I always recheck my BC when I get a singular matrix. Inverted mesh elements are not necesarily fully dammaging, but with ALE it indicates potential weak regions, or even faults so its worth to investigat the location and the deformed mesh.
Often its instructif to use plotting while solving to see how the solver progresses (not only the convergence value, but a few dependent paramters how they oscillate, or the ALE mesh how it distorts
Hi check (search) the forum there are many discussions around those points. I always recheck my BC when I get a singular matrix. Inverted mesh elements are not necesarily fully dammaging, but with ALE it indicates potential weak regions, or even faults so its worth to investigat the location and the deformed mesh. Often its instructif to use plotting while solving to see how the solver progresses (not only the convergence value, but a few dependent paramters how they oscillate, or the ALE mesh how it distorts -- Good luck Ivar
